Epson XP 3100 PDF Druck
Verfasst: Fr 10 Apr, 2020 10:39
beim Drucken eines PDF Files aus dem Browser: Das PDF File wird mit einem unbekannten Zeichensatz gedruckt und ist damit unlesbar und unbrauchbar.
Vielen Dank für die Unterstützung und frohe Ostern
Andreas
Auszug aus /var/log/turboprint/print.log:
backchannel_fd=5
tpprint 2.49-1 x64 (28-NOV-2019) - TurboPrint printer driver
10-Apr-2020 11:08
PPD file: /etc/cups/ppd/XP3100series-TurboPrint.ppd
header file: /tmp/pstoturboprint21094.chunk
set_feature: no value given
duplex overwritten by ---Duplex=DuplexNoTumble
::set_info_paths: setting preview file to /var/spool/turboprint/rz5j/zmf/374.zmf
GPL Ghostscript Zedo3 9.05 (2012-02-08)
Copyright (C) 2010 Artifex Software, Inc. All rights reserved.
Processing pages 1 through 1.
Page 1
Can't find CID font "HelveticaNeueLTW1G-Bd".
Attempting to substitute CID font /Adobe-Identity for /HelveticaNeueLTW1G-Bd, see doc/Use.htm#CIDFontSubstitution.
The substitute CID font "Adobe-Identity" is not provided either. attempting to use fallback CIDFont.See doc/Use.htm#CIDFontSubstitution.
Loading a TT font from %rom%Resource/CIDFSubst/DroidSansFallback.ttf to emulate a CID font Adobe-Identity ... Done.
Can't find CID font "HelveticaNeueLTW1G-Roman".
Attempting to substitute CID font /Adobe-Identity for /HelveticaNeueLTW1G-Roman, see doc/Use.htm#CIDFontSubstitution.
# CountGray=1 CountRGB=234 CountCMYK=0 DocWidth=595 DocHeight=842 AutoRotate=0 DocCopies=1Filetype=PBM Plusbits_per_pixel=32 bytes_per_line=11904 width=2976 height=4209
RGB mode 8bit
printable_width=8028 max_printable_width=15000
command level=21 feature set=5 duplex=2
Printer=Epson_XP3100series; Module=Epson; Id=XP305
Colormode=2; Cartridge=0=Color; Quality=1=Low; Paper=0=Plain paper
Pagesize=3=A4; Paper Input=0=Automatic Feed; Paper Output=0=Front
Duplex=1=On (Portrait); Copies=1; Mirror=0; Dithering=0; Flip=0
Page x=2890 y=4123; AppDpi x=360 y=360; DitDpi x=360 y=360;
PrnDpi x=360 y=360; Overlay=0
Print Direction=Bidirectional (0:1,2,0,0);
tpfile::get_patchsample_table: paper=Plain paper
gamma 100 max 100 saturation 1000 for channel 0
gamma 100 max 100 saturation 1000 for channel 1
correction=32539
gamma 100 max 100 saturation 1000 for channel 2
correction=33434
gamma 100 max 100 saturation 1000 for channel 3
correction=32557
matchtable->profile_datafile_version = 1
shadow: 0 => adjust 100 min 50/10 max 50; grey: a=0 b=-30; colorspace=APPLE; cmykspace=0; intent=perceptual; M2; daylight = 5000K
matchtable->numchannels=4
multi_profile_switch=200 multi_c2_switch=100 multi_m2_switch=100
ucr_up=255; max_ink=638; ucr_add=0
polyfit mode=0 channels=4 terms=57 patches=528
have_brighter_grey=0
max_dens_val[GREY_BRIGHT]=-32768 min_dens_val[GREY_BRIGHT]=32767 max_dens_val[GREY_BRIGHTER]=-32768 min_dens_val[GREY_BRIGHTER]=32767
bright_cyan_fac=0 bright_magenta_fac=0
black_fac=100 cyan_fac=47 magenta_fac=52 yellow_fac=34
printer white:l=937 a-005 b+000
printer white poly:l=937 a-005 b+000
printer black:l=249 a+007 b+029
printer black poly:l=240 a+009 b+019
printer darkest poly:l=240 a+009 b+019
black l=00 a+00 b+00 => l=240 a+009 b+019: K99 C00 M00 Y00 c00 m00 k00 g00 h00
black94 l=06 a+00 b+00 => l=292 a+017 b+029: K66 C57 M50 Y46 c00 m00 k00 g00 h00
black87 l=17 a+00 b+00 => l=345 a+026 b+043: K40 C72 M62 Y49 c00 m00 k00 g00 h00
black75 l=34 a+00 b+00 => l=458 a+013 b-021: K01 C92 M58 Y37 c00 m00 k00 g00 h00
black62 l=48 a+00 b+00 => l=547 a+000 b-039: K00 C47 M31 Y27 c00 m00 k00 g00 h00
black50 l=60 a+00 b+00 => l=637 a-001 b-040: K00 C30 M20 Y18 c00 m00 k00 g00 h00
black37 l=71 a+00 b+00 => l=718 a-002 b-040: K00 C20 M12 Y11 c00 m00 k00 g00 h00
black25 l=82 a+00 b+00 => l=795 a-003 b-040: K00 C11 M07 Y05 c00 m00 k00 g00 h00
black12 l=91 a+00 b+00 => l=868 a-006 b-029: K00 C05 M02 Y01 c00 m00 k00 g00 h00
white l=99 a+00 b+00 => l=936 a-005 b+000: K00 C00 M00 Y00 c00 m00 k00 g00 h00
cyan l=89 a-54 b-17 => l=778 a-165 b-200: K00 C28 M00 Y00 c00 m00 k00 g00 h00
magenta l=64 a+87 b-52 => l=656 a+465 b-124: K00 C00 M48 Y00 c00 m00 k00 g00 h00
yellow l=97 a-14 b+86 => l=879 a-015 b+604: K00 C00 M00 Y53 c00 m00 k00 g00 h00
red l=58 a+77 b+70 => l=590 a+458 b+365: K00 C00 M99 Y92 c00 m00 k00 g00 h00
green l=86 a-84 b+72 => l=722 a-257 b+372: K00 C26 M00 Y56 c00 m00 k00 g00 h00
blue l=32 a+60 b-105 => l=466 a+084 b-379: K00 C97 M38 Y00 c00 m00 k00 g00 h00
epson::setup_printer_info: number of channels: 4
epson::setup_printer_info: bits per pixel: 2
Epson init string: ESC ( K 2 ESC U 0 ESC ( m 40 ESC ( e 17
epson::setup_printer_info: color nozzles:60 color spacing:180 black nozzles:180 black spacing:180
epson::setup_printer_info: c70 nonstandard head layout
epson_info.top_feed=402 epson_info.top_margin=-719 epson_info.bottom_margin=8333 epson_info.unit_y=720 epson_info.y_pixel_units=2
esc(C 20e3 esc(c fffffd31 208d
Microweave information
nozzlespacing=2 package=2 totalpasses=2 unitpixels=2
numbuffers=5
calculate_weave_parameters_sub(min)
nozzlenum=60 used_nozzles=59 cycle_length=2 feed_sum=2
Sequence 1>1(0),1>0(0),
calculate_weave_parameters_sub(reg)
nozzlenum=60 used_nozzles=59 cycle_length=2 feed_sum=118
Sequence 59>1(0),59>0(0),
feed_total=118 feed_minimum_total=2 feed_buildup_total=0 feed_builddown_total=0
total_passes=2 buildup_steps=4 builddown_steps=4
borderless_interleave num_headbuffers=15
borderless_buildup=0 buildup_steps=4 y_builddown=4403 max_height=4525 builddown_steps=4
y_cover=180 color_max_off=120 unit_pixels=2
esc(m 40
Colormatch file=XP300; Curves=360dpi_xp305; Table=plain_paper
Total memory usage=1465662
PREVIEW y_offset=43 org_height=4209 src_scanline=42 preview_scanline=6
calculate_dim: print left=0 top=0 width=2890 height=4123
calculate_dim: section left=43 top=43 width=2890 height=4123
Printer: resolution x_dpi=360 y_dpi=360 color_mode=2
tpprint::update_ink: black_type=0 rgb_mode=0
Time for <Profile> = 266
Time for <Color> = 506
Time for <Dither> = 147
Time for <Print> = 27
Time for <Total> = 998
Line counters: skip=0; bitmap=0; others=4123; 8bit=0; white=2089; b/w=0
Color 0 sum: 10
Color 1 sum: 20
Color 2 sum: 19
Color 3 sum: 13
total sum: 62
pixmap_class::open: end of file reached
numbuffers=5
esc(m 40
tpprint: at end of main result=-21
job cancelling procedure - TPPID=21121 GSPID=21123 PVPID=
Andreas
backchannel_fd=5
10-Apr-2020 11:08
Page 1
RGB mode 8bit
correction=32539
correction=33434
correction=32557
numbuffers=5
esc(m 40
Color 0 sum: 10
Color 1 sum: 20
Color 2 sum: 19
Color 3 sum: 13
total sum: 62
numbuffers=5
esc(m 40
