Canon PIXMA iP1200 - can't open colormatch file
Verfasst: Do 30 Okt, 2008 20:25
Hi.
Sorry, I'm not german but there is no english forum so I ask here. I've installed latest turboprint in Ubuntu 8.04. I have Canon PIXMA iP1200 color printer. When I try to print anything from any application, it failed. In the /var/log/turboprint/print.log there is error message:
tpfile::load_colormatch_curves: printmode section not found
FATAL ERROR:
pdrive::begin_page: can't open colormatch file
I've search the web for that messages but I can't find any help. Thanks. Here is complete log:
NEW PRINT JOB Ã Â t okt 30 20:11:34 CET 2008 (pstoturboprint 2.05-1)
job-id 30
user dvh
title pokusna_tlac
options PageSize=A4 InputSlot=AutomaticFeed job-uuid=urn:uuid:20430c05-2870-368d-6ae5-7ca5b3074a05
queue tlaciaren
drwxr-xr-x 2 dvh dvh 20480 2008-10-30 19:07 /usr/share/turboprint/printers
linux-gate.so.1 => (0xb7eef000)
libm.so.6 => /lib/tls/i686/cmov/libm.so.6 (0xb7eb8000)
libc.so.6 => /lib/tls/i686/cmov/libc.so.6 (0xb7d69000)
/lib/ld-linux.so.2 (0xb7ef0000)
/usr/bin/tpprint -v2 -l/var/log/turboprint/print.log --ppdfile=/etc/cups/ppd/tlaciaren.ppd --psfeatures /tmp/pstoturboprint6750.chunk /tmp/pstoturboprint6750.var
check_flag_file: opening /var/turboprint/dvh/prv/tlaciaren
check_flag_file: opening /var/turboprint/dvh/sml/tlaciaren
ZEDOPARM="$ZEDOPARM zedoPageRegion=A4"
ZEDOPARM="$ZEDOPARM zedoMediaType=Plainpaper_4"
ZEDOPARM="$ZEDOPARM zedoCartridgeType=Color"
ZEDOPARM="$ZEDOPARM zedoInputSlot=AutomaticFeed"
ZEDOPARM="$ZEDOPARM zedoColorspace=0"
ZEDOPARM="$ZEDOPARM zedoCMYKspace=0"
ZEDOPARM="$ZEDOPARM zedoIntent=perception_0"
ZEDOPARM="$ZEDOPARM zedoColorY=0"
ZEDOPARM="$ZEDOPARM zedoColorC=0"
ZEDOPARM="$ZEDOPARM zedoInklimitY=0"
ZEDOPARM="$ZEDOPARM zedoInklimitM=0"
ZEDOPARM="$ZEDOPARM zedoInklimitC=0"
ZEDOPARM="$ZEDOPARM zedoInklimitK=0"
ZEDOPARM="$ZEDOPARM zedoRefLight=65"
ZEDOPARM="$ZEDOPARM zedoGreyToneA=0"
ZEDOPARM="$ZEDOPARM zedoGreyToneB=0"
ZEDOPARM="$ZEDOPARM zedoUCR=0"
ZEDOPARM="$ZEDOPARM zedoTAC=0"
ZEDOPARM="$ZEDOPARM zedoBrightC=0"
ZEDOPARM="$ZEDOPARM zedoBrightM=0"
ZEDOPARM="$ZEDOPARM zedoDuplexadvanced=manual"
ZEDOPARM="$ZEDOPARM zedoBorderlessExpand=2"
ZEDOPARM="$ZEDOPARM zedoResolution=600x600dpi"
ZEDOPARM="$ZEDOPARM zedoPrinterDriver=Canon_PIXMA_iP1200"
BORDERLESS=0
PVXDPI=87
PVYDPI=87
PVWIDTH=719
PVHEIGHT=1017
GSRESULT=GPL Ghostscript 8.61 (2007-11-21) GSVERSION=GPL GSMAJOR=8 GSMINOR=61 GSCUPSDEVICE=1
GSCOMMANDLINE=gs -sDEVICE=cups -r600x600 -dNOMEDIAATTRS -dSAFER -dNOPAUSE -dBATCH
TPCOMMANDLINE=/usr/bin/tpprint --cups -v2 -l/var/log/turboprint/print.log --ppdfile=/etc/cups/ppd/tlaciaren.ppd --psheader=/etc/cups/ppd/tlaciaren.ppd ---zedoPageRegion=A4 ---zedoMediaType=Plainpaper_4 ---zedoCartridgeType=Color ---zedoInputSlot=AutomaticFeed ---zedoColorModel=RGB ---zedoDithering=ErrorDiffusion ---zedoMirror=0 ---zedoDuplexAdjust=0 ---zedoColorspace=0 ---zedoCMYKspace=0 ---zedoIntent=perception_0 ---zedoIntensity=0 ---zedoBrightness=0 ---zedoContrast=0 ---zedoColorY=0 ---zedoColorM=0 ---zedoColorC=0 ---zedoColorK=0 ---zedoInklimitY=0 ---zedoInklimitM=0 ---zedoInklimitC=0 ---zedoInklimitK=0 ---zedoRefLight=65 ---zedoGreyToneA=0 ---zedoGreyToneB=0 ---zedoGamut=0 ---zedoUCR=0 ---zedoTAC=0 ---zedoBrightC=0 ---zedoBrightM=0 ---zedoDuplexadvanced=manual ---zedoBorderlessExpand=2 ---zedoResolution=600x600dpi ---zedoDuplex=None ---zedoPrinterDriver=Canon_PIXMA_iP1200 --jobid=30 --username=dvh '--title=pokusna_tlac'
COMPLETEPIPE=/usr/share/turboprint/lib/tpstdin --paste /tmp/pstoturboprint6750.chunk | gs -sDEVICE=cups -r600x600 -dNOMEDIAATTRS -dSAFER -dNOPAUSE -dBATCH -sOutputFile=/tmp/pstoturboprint6750.fifo - >> /var/log/turboprint/print.log
PREVIEWPIPE=
Copyright (C) 2007 Artifex Software, Inc. All rights reserved.
tpprint 2.05-1 (23-OCT-2008) - TurboPrint printer driver
::set_info_paths: setting preview file to /var/turboprint/dvh/zmf/30.zmf
Filetype=CupsRasterbits_per_pixel=32 bytes_per_line=19200 width=4800 height=6825
RGB Mode
Printer=Canon_PIXMA_iP1200; Module=Canon; Id=ip2200
Colormode=2; Cartridge=0=Color; Quality=1=Medium; Paper=0=Plain paper
Pagesize=4=A4; Paper Input=0=Automatic Feed; Paper Output=0=Front
Page x=4800 y=6825; AppDpi x=600 y=600; DitDpi x=600 y=600;
FATAL ERROR:
600 pdrive::begin_page: temp_bitmap_buffer
19200 pdrive::begin_page: temp_buffer
100 inifile::open(buffer)
42279 inifile::open(buffer)
19201 pixmap::open: bitshift_buffer
19200 pixmap::open: pixmap_buffer
14400 pcx_class: temp buffer
Total memory usage=114980
------------ End of print job - result = 1 ------------
job cancelling procedure - TPPID=6772 GSPID=6774 PVPID=
FATAL ERROR:
job-id 30
user dvh
title pokusna_tlac
queue tlaciaren
BORDERLESS=0
PVXDPI=87
PVYDPI=87
PVWIDTH=719
PVHEIGHT=1017
PREVIEWPIPE=
RGB Mode
FATAL ERROR:
