es ist ein Canon i865 wie in Subject.
Ich benutze Canon Photo Papier Pro.
Es kommt überhaupt kein Fehler vor.
Mein Computer ist ein dual-boot Computer. Ich starte erst Linux dann Windows und drucke das selber File auf das selbe Papier - ich bekomme:
tail /var/cups/error_log:
I [22/Dec/2008:14:44:07 +0100] Using policy "default" as the default!
I [22/Dec/2008:14:44:07 +0100] Full reload is required.
I [22/Dec/2008:14:44:07 +0100] Loaded MIME database from '/etc/cups': 37 types, 40 filters...
I [22/Dec/2008:14:44:07 +0100] Loading job cache file "/etc/cups/yes/job.cache"...
I [22/Dec/2008:14:44:07 +0100] Full reload complete.
I [22/Dec/2008:14:44:07 +0100] Cleaning out old temporary files in "/var/spool/cups/tmp"...
I [22/Dec/2008:14:44:07 +0100] Listening to 127.0.0.1:631 on fd 1...
E [22/Dec/2008:14:44:07 +0100] Unable to bind socket for address 127.0.0.1:631 - Address already in use.
I [22/Dec/2008:14:44:08 +0100] Listening to /var/run/cups/cups.sock on fd 3...
I [22/Dec/2008:14:44:08 +0100] Resuming new connection processing...
Es gibt nur I Linie.
cat /var/log/turboprint/print.log
NEW PRINT JOB Mon Dec 22 18:03:49 CET 2008 (pstoturboprint 2.05-1)
job-id 160
user doma
options media=A4Borderless sides=one-sided finishings=3 number-up=1 zedoUserColor=0 zedoPreview=preview-off columns=1 cpi=10 lpi=6 zedoColorspace=5 Resolution=600x600dpi_3 zedoColorModel=RGB zedoDithering=ErrorDiffusion MediaType=KodakPremium-Ultima_4 InputSlot=AutomaticFeed zedoMirror=0 zedoDuplexAdjust=0 zedoBrightness=0 zedoContrast=0 zedoGamut=0 zedoIntensity=0 zedoColorY=30 zedoColorC=20 zedoColorM=0 zedoColorK=0 zedoCMYKspace=0 zedoIntent=none_0 zedoInklimitY=0 zedoInklimitC=0 zedoInklimitM=0 zedoInklimitK=0 zedoRefLight=65 zedoGreyToneA=0 zedoGreyToneB=0 zedoUCR=0 zedoTAC=0 zedoBrightC=0 zedoBrightM=0 zedoBorderlessExpand=2 zedoDuplexadvanced=auto PageSize=4x6inBorderless job-uuid=urn:uuid:bad9e343-a086-37e7-5e16-35d1aa940122
queue tp0
drwxr-xr-x 2 root root 20480 Dec 5 12:53 /usr/share/turboprint/printers
linux-gate.so.1 => (0xffffe000)
libm.so.6 => /lib/libm.so.6 (0xb8068000)
libc.so.6 => /lib/libc.so.6 (0xb7f25000)
/lib/ld-linux.so.2 (0xb80b2000)
/usr/bin/tpprint -v2 -l/var/log/turboprint/print.log --ppdfile=/etc/cups/ppd/tp0.ppd --psfeatures /tmp/pstoturboprint14908.chunk /tmp/pstoturboprint14908.var
borderless offset corrected to left =38 top=18
check_flag_file: opening /var/turboprint/doma/prv/tp0
check_flag_file: opening /var/turboprint/doma/sml/tp0
ZEDOPARM="$ZEDOPARM zedoPageRegion=4x6inBorderless"
ZEDOPARM="$ZEDOPARM zedoMediaType=KodakPremium-Ultima_4"
ZEDOPARM="$ZEDOPARM zedoInputSlot=AutomaticFeed"
ZEDOPARM="$ZEDOPARM zedoColorspace=5"
ZEDOPARM="$ZEDOPARM zedoCMYKspace=0"
ZEDOPARM="$ZEDOPARM zedoIntent=none_0"
ZEDOPARM="$ZEDOPARM zedoColorY=30"
ZEDOPARM="$ZEDOPARM zedoColorC=20"
ZEDOPARM="$ZEDOPARM zedoInklimitY=0"
ZEDOPARM="$ZEDOPARM zedoInklimitM=0"
ZEDOPARM="$ZEDOPARM zedoInklimitC=0"
ZEDOPARM="$ZEDOPARM zedoInklimitK=0"
ZEDOPARM="$ZEDOPARM zedoRefLight=65"
ZEDOPARM="$ZEDOPARM zedoGreyToneA=0"
ZEDOPARM="$ZEDOPARM zedoGreyToneB=0"
ZEDOPARM="$ZEDOPARM zedoUCR=0"
ZEDOPARM="$ZEDOPARM zedoTAC=0"
ZEDOPARM="$ZEDOPARM zedoBrightC=0"
ZEDOPARM="$ZEDOPARM zedoBrightM=0"
ZEDOPARM="$ZEDOPARM zedoDuplexadvanced=auto"
ZEDOPARM="$ZEDOPARM zedoBorderlessExpand=2"
ZEDOPARM="$ZEDOPARM zedoResolution=600x600dpi_3"
ZEDOPARM="$ZEDOPARM zedoPrinterDriver=Canon_i865"
GSXDPI=612
GSYDPI=612
GSWIDTH=2449
GSHEIGHT=3672
TPWIDTH=4082
TPHEIGHT=6121
TPXOFFSET=38
TPYOFFSET=18
BORDERLESS=1
PVXDPI=170
PVYDPI=170
PVWIDTH=680
PVHEIGHT=1021
GSRESULT=GPL Ghostscript 8.62 (2008-02-29) GSVERSION=GPL GSMAJOR=8 GSMINOR=62 GSCUPSDEVICE=1
GSCOMMANDLINE=gs -sDEVICE=cups -r612x612 -g2449x3672 -dNOMEDIAATTRS -dSAFER -dNOPAUSE -dBATCH
TPCOMMANDLINE=/usr/bin/tpprint --cups -v2 -l/var/log/turboprint/print.log --ppdfile=/etc/cups/ppd/tp0.ppd --psheader=/etc/cups/ppd/tp0.ppd ---zedoPageRegion=4x6inBorderless ---zedoMediaType=KodakPremium-Ultima_4 ---zedoInputSlot=AutomaticFeed ---zedoColorModel=RGB ---zedoDithering=ErrorDiffusion ---zedoMirror=0 ---zedoDuplexAdjust=0 ---zedoColorspace=5 ---zedoCMYKspace=0 ---zedoIntent=none_0 ---zedoIntensity=0 ---zedoBrightness=0 ---zedoContrast=0 ---zedoColorY=30 ---zedoColorM=0 ---zedoColorC=20 ---zedoColorK=0 ---zedoInklimitY=0 ---zedoInklimitM=0 ---zedoInklimitC=0 ---zedoInklimitK=0 ---zedoRefLight=65 ---zedoGreyToneA=0 ---zedoGreyToneB=0 ---zedoGamut=0 ---zedoUCR=0 ---zedoTAC=0 ---zedoBrightC=0 ---zedoBrightM=0 ---zedoDuplexadvanced=auto ---zedoBorderlessExpand=2 ---zedoResolution=600x600dpi_3 ---zedoDuplex=None ---zedoPrinterDriver=Canon_i865 --jobid=160 --username=doma '--title=dom_5825.jpg'
COMPLETEPIPE=/usr/share/turboprint/lib/tpstdin --paste /tmp/pstoturboprint14908.chunk | gs -sDEVICE=cups -r612x612 -g2449x3672 -dNOMEDIAATTRS -dSAFER -dNOPAUSE -dBATCH -sOutputFile=/tmp/pstoturboprint14908.fifo - >> /var/log/turboprint/print.log
PREVIEWPIPE=
tpprint 2.06-1 (14-NOV-2008) - TurboPrint printer driver
Copyright (C) 2008 Artifex Software, Inc. All rights reserved.
This software comes with NO WARRANTY: see the file COPYING for details.
::set_info_paths: setting preview file to /var/turboprint/doma/zmf/160.zmf
Filetype=CupsRasterbits_per_pixel=32 bytes_per_line=9796 width=2449 height=3672
RGB Mode
Printer=Canon_i865; Module=Canon; Id=i865
Colormode=2; Cartridge=0=Color; Quality=3=Super; Paper=10=Kodak Premium/Ultima
Pagesize=12=4x6" Borderless; Paper Input=0=Automatic Feed; Paper Output=0=Front
Page x=2518 y=3766; AppDpi x=600 y=600; DitDpi x=600 y=600;
tpfile::get_patchsample_table: paper=Kodak Premium Picture Paper Satin
table::get_patchsample_struct: default_bright_ink set to default 100
grey: a=0 b=0; colorspace=ECI; cmykspace=0; intent=no-correction; daylight = 5000K
print_color_chart_mode=1
bright_cyan_fac=-1 bright_magenta_fac=-1
black_fac=100 cyan_fac=107 magenta_fac=99 yellow_fac=93
black l=00 a+00 b+00 => l=000 a+000 b+000: K99 C25 M25 Y25 c00 m00 k00 g00
black94 l=06 a+00 b+00 => l=062 a+000 b+000: K88 C60 M60 Y60 c00 m00 k00 g00
black87 l=17 a+00 b+00 => l=173 a+000 b+000: K76 C60 M60 Y60 c00 m00 k00 g00
black75 l=34 a+00 b+00 => l=346 a+000 b+000: K53 C56 M56 Y56 c00 m00 k00 g00
black62 l=48 a+00 b+00 => l=485 a+000 b+000: K31 C51 M51 Y51 c00 m00 k00 g00
black50 l=60 a+00 b+00 => l=607 a+000 b+000: K08 C46 M46 Y46 c00 m00 k00 g00
black37 l=71 a+00 b+00 => l=714 a+000 b+000: K00 C37 M37 Y37 c00 m00 k00 g00
black25 l=82 a+00 b+00 => l=815 a+000 b+000: K00 C24 M24 Y24 c00 m00 k00 g00
black12 l=91 a+00 b+00 => l=910 a+000 b+000: K00 C12 M12 Y12 c00 m00 k00 g00
white l=99 a+00 b+00 => l=999 a+000 b+000: K00 C00 M00 Y00 c00 m00 k00 g00
cyan l=86 a-95 b-24 => l=860 a-956 b-241: K00 C99 M00 Y00 c00 m00 k00 g00
magenta l=69 a+99 b-47 => l=693 a+993 b-472: K00 C00 M99 Y00 c00 m00 k00 g00
yellow l=97 a-11 b+107 => l=969 a-113 b+1077: K00 C00 M00 Y99 c00 m00 k00 g00
red l=63 a+96 b+109 => l=634 a+963 b+1092: K08 C00 M98 Y98 c00 m00 k00 g00
green l=82 a-137 b+81 => l=819 a-1374 b+819: K08 C98 M00 Y98 c00 m00 k00 g00
blue l=33 a+46 b-109 => l=335 a+468 b-1089: K08 C98 M98 Y00 c00 m00 k00 g00
canon_info.model_level=3
canon::setup_printer_info: bits per pixel: 4
canon::setup_printer_info: S600/800 mode
canon::setup_printer_info: s600 split colors
canon::setup_printer_info: i865 photo black used
Canon init string: esc(c 30 9 4
esc(t 80 80 1 esc(l 34 d
esc(p 179 0 fc 0
Colormatch file=BCI3e6; Curves=2400dpi_i865; Table=kodak_premiumsatin
Total memory usage=2569988
PREVIEW y_offset=0 org_height=3766 src_scanline=-1 preview_scanline=0
orig: cups left=46 top=46 width=2400 height=3600 (pixels)
cups left=22 top=10 width=2448 height=3672 (pixels)
calculate_dim: print left=22 top=10 width=2448 height=3672
calculate_dim: section left=0 top=0 width=2449 height=3672
Time for <Profile> = 230
Time for <Color> = 3090
Time for <Dither> = 1940
Time for <Print> = 220
Time for <Total> = 5430
Line counters: skip=10; bitmap=0; others=3672; 8bit=0; white=0; b/w=0
Color 0 sum: 83
Color 1 sum: 83
Color 2 sum: 83
Color 3 sum: 123
total sum: 372
job cancelling procedure - TPPID=14927 GSPID=14929 PVPID=
